W208 front bumber removal
Lord Iffy
1998 CLK 230K
Hello,
I would kindly like to ask you whether you know how to remove the red marked part on the front bumper of 1998 W208 CLK. I know that there are two screws but I believe somethin more has to been done in order to remove it. Thank you very much.
Its clipped under neath also and you will have too take the bumper off to get at these
I know about two clips on the lower side, are there more of them? Removing the bumper is the worst case scenario, but if there is no other possibility... I will have to try it (or the mechanics, not me).
The issue is, that I had some minor parking accident and the end of the moulding which is left from the panel has to be under the panel, but is not. Maybe if it easier to remove the moulding I shall try that.
To remove the side mouldings and no.plate moulding you have to remove the bumper they are clipped in from the back and its easy removing the bumper 40mins work tops
