stchris356
OK, My heater fan stopped working but does work from time to time.
I purchased a new resistor, fitted it and the fan ran perfectly on all speeds, brilliant I thought until I came out the next morning to discover a completley flat battery.
Attached jump leads to find the fan constantly running.
If the ignition is turned on the fan then operates normally but when the ignition is turned off the fan also goes off............for about 30 seconds(just enough time to allow you to get out of the car and lock it!!) and then comes back on and flattens the battery overnight
Any ideas or is it a faulty new resistor?
Chris
Chris
