W208 Roof problem
Discussion in 'Bodywork' started by Andymac10, Jul 3, 2019.
  1. Andymac10
    Andymac10 New Member
    5
    Jun 30, 2019
    Canada
    Car:
    2003 CLK 430
    Help! Roof will not open automatically, open handle, windows go down, pull switch, light blinks (3Hz) nothing happens, roll bar does not retract. Checked Luggage cover switch at N52 plug and okay. Not sure how to check trunk lid micro switch.
    After opening the roof manually all is well, I close the hydraulic valve and the roof (and headrests) behave exactly as they should. Everything works and I hear that wonderful "bing" chime.
    Headrests do not behave and could be related. Headrests go up and down with switch but do not automatically stop. They do not move when trying to open roof. I have checked the micro switches at the headrest frame and both go to ground when raising and lowering. Maybe normal behaviour but not sure.
    I get a B1650-001 micro switch position not plausible message on my Autel scanner, and someone said it was the roll bar micro switches but not sure.
    The only switch I can think of is the one in the top of the windshield, when watching the process on the Autel scanner I open the handle and it goes from closed/locked to closed/unlocked. Could that be where the issue is?
    But the windows go down so it must see something.
    Any help appreciated.
  2. OP
    OP
    Andymac10
    5
    Jun 30, 2019
    Canada
    Car:
    2003 CLK 430
    Problem finally solved. It turned out to be the S84/13 micro switch on the left hinge area. It is the soft top open/close limit switch. If I open the roof a bit more than the wires do, it trips and the roof opens. Now I just have to buy the switch and pull the car apart again to install it. Oh wait, maybe I'll just keep opening a bit more and save myself about $300.
  3. eddie007
    eddie007 New Member
    27
    Sep 5, 2016
    Car:
    R107 450
    Hi Andy, just purchased w208 cab with roof problems any info appreciated, I think I have same problem S84/13 switch any picture where located ? . Windows go down hatch opens then that's it? Thanks Ed
  4. markmifsud
    markmifsud Hardcore MB Enthusiast
    2,269
    Nov 17, 2008
    North Weald, Essex and Bromley, London
    Car:
    CLK320 CAB (A208) 02
Share This Page
