w208 speed pulse pickup
Discussion in 'Electronics' started by ghouluk, May 5, 2011.
  1. ghouluk
    ghouluk Active Member
    85
    May 2, 2011
    Car:
    clk320
    Hi folks,
    does anybody know an easy place to pick up the speed pulse for GPS on a 2001 CLK 320?
    i'm assuming its not on the iso, as none of the pinouts mention it - can i grab it from the back of the instrument cluster or similar?
    cheers
    Rob
  2. mr. shr
    mr. shr MB Enthusiast
    1,879
    Apr 22, 2004
    I did this very job on my year 2000 W208 a few years back.
    Firstly check whether it's already connected on the ISO block. (Pin 1 on block A).
    If there is no cable there, then you can pick up the speed pulse from the passenger side 'A' pillar.
    Remove passenger side door sill, side kick plate and footwell carpet (help with access).
    Open up the black cable trunking and look for a blue connector block.
    Your speed pulse should be one of these wires. Should be green with somthing.
    (From memory, think mine was green with violet).
  3. OP
    OP
    ghouluk
    85
    May 2, 2011
    Car:
    clk320
    got the car today, and indeed its present on pin 1 :)
    GPS fitted - all good, first job done on a new car is always a good feeling.
    thanks folks
Share This Page
