Hi All,
CLK320 Cab 1999 Facelift
Have the strangest issue, been happening for year or so, now getting worse, the windows stop working or work intermittently at about the same time but not always i hear a clicking sound from what i think is the right hand side vent area behind the dash or directly behind the ignition switch, at first i didnt link the 2 as i assumed it was the vent stepper motor, however even with the digital climate control off it still happens and sounds like a relay struggling - i'm pretty happy its not from the door,
When it happens the bits that stop working are......
All Windows - 4 switches and the one touch cab button
Mirrors - But do adjust if I use the memory seat function
The rear headrests
Bits that still work
Parking sensor disable
Heated seats
ECP disable
Ive taken out the drivers side fusebox and googled but just get stepper motor and the door module, which is in the door I believe, it sounds like a relay behind the ignition switch, but can't find anything on line,
Any idea what on earth it could be?
Cheers
Andy
The rear headrests
Heated seats
ECP disable
Cheers
Andy
