W209 Battery Replacement
Discussion in 'Electronics' started by comports, Feb 27, 2012.
  1. comports
    comports Active Member
    714
    May 10, 2007
    Colchester, Essex
    Car:
    CLK 350 Cabriolet
    Hi Folks - Long time no visit (sorry)
    My battery is completely dead and long overdue for a replacement so I ordered one today and here in a couple of days. I haven't used the car for a few months and even then only sporadically as my daily driver is left at the station car park.!
    My Question - Having a nosey around yesterday I found the battery (tucked nicely up the back of the engine bay in front of the passenger side strut and under the air filter (I assume) but it looks a very small gap with not a lot of room.
    Question is - is it easy to get it out and replace with the new one, how is it secured in place as I couldn't see much in the way of securing bolts and is there anything I should know/be careful of when replacing it.?
    Many Thanks for you help as always..!
  2. SKIPPERDOG
    SKIPPERDOG Member
    57
    Feb 14, 2011
    dublin
    Car:
    211 320cdi
    It's handy all you need is 13mm socket long extension and a 10 or 13 spanner there is 2 bolts down the side of the battery the hold it in it pulls up its tight but shouldn't be 2 hard 2 do
  3. OP
    OP
    comports
    714
    May 10, 2007
    Colchester, Essex
    Car:
    CLK 350 Cabriolet
    Thanks Skipper..!
    It has it's MOT on Friday and probably done all of about 2,000 miles since last years.! shame to see it sit there really... Still - Summers nearly here (huhum) so will get some use soon.:thumb:
  4. Blackthorn
    Blackthorn New Member
    2
    Mar 8, 2011
    Car:
    W209 CLK320
    It is a tight squeeze, and it's very heavy.
    You may need to do a bit of resetting when it's back in, eg; seats, roof, windows, service interval indicator.
  5. Bobby Dazzler
    Bobby Dazzler MB Club Veteran
    16,184
    Jan 21, 2005
    Mittel England
    Car:
    ML AMG-line Black Series
    I suspect it's identical to my W203. I watched my battery being replaced, and I think the only thing that might thwart a DIY attempt is having a long enough extension for your socket set.
  6. sjmaxwell
    sjmaxwell MB Enthusiast
    3,342
    Aug 15, 2003
    Chatham, Kent
    Car:
    2012 E Class E63 PPP, 2012 SLK55 AMG
    Its also great fun trying to get a pipe and the wiring out of the way at the side where the bracket holding the battery has to go!:D
Share This Page
