colh
My driver's seat headrest is in the fully up position, and not responding to the 'down' switch. Passenger side is all working fine. I've seen this general problem mentioned quite a few times on the forums, usually with slightly varying symptoms. These are mine:
- The rest retracts fully when I tip the seat forward, and extends fully when I tip it back again.
- When I press the up switch I can hear (a relay?) under the seat go click.....click..click. (I also hear this on the passenger side, when its fully extended).
- When I press the down switch I hear nothing. (The passenger side also makes no noise, pressing the down switch when it is fully *retracted*)
- Immediately after locking the seat back, while the rest is *still extending*, if I press the up switch then it stops part way. I can't make it stop by pressing the down switch, only the up. (Mind you, after doing this, *none* of the driver's seat switches work until I tip seat forward/back again, and let the rest extend fully!)
Before seeing all the similar posts I had been assuming it was a faulty switch, and that still does seem to best fit my symptoms. But I'm reluctant to chuck it at the dealer and perhaps end up paying for un-necessary parts.
Anyone got any ideas of other things to try...?
