Hi everyone,
Im having some problems with a 52 plate Clk. A little while back the car was being unlocked with the fob and at the same time the driver side door handle was pulled to open the door. So basically the handle was pulled at the exact same time as the button to unlock the car was pressed on the fob!
Now the door does not lock properly at all. It wont lock with the fob, with the central locking button in the car or if the door pin is pushed down by hand. When tried with the fob the door pin just goes up and down very quickly a number of times but will not lock and always ends up in the open position. And if pushed down by hand it just slowly raises itself again about halfway and stops.
So it just wont lock anymore. Does anyone have any ideas on what is causing this and what needs to be done to resolve it?
Many Thanks
Many Thanks
