KLP 92
I've just retrofitted comand into my CLk2006 CLK320 CDI.
I installed Comand part number: A2098207289
I installed AUX lead: A 169 540 49 08.
The 2 problems i have is that when i listen a radio station and switch the car off, when i get back into the car later it will play a CD in the changer.
If i listen to the CD and switch the car off it will start next time on the radio, on the first FM station (normally Absolute FM, any FM station first in ALPHABETICAL order). If i switch the car off again it will start with the CD i listened to before.
Basically the comand remembers the Cd i last listedned to, the track number and time into the track, radio presets etc but the problem is just it won#'t switch on next time listening to the same source as before.
The next issue is that the AUX in doesn't work. The part number for the lead was from a thread on this forum but it wouldn't fit the quadlock connector with the white tab in place as they have specific small grooves for the connector to slot into. I modified the tab and plugged the lead into the empty connector of the comand but stil no AUX in.
Any help will be greatly appreciated. the Comand unit was a brand new unit.
