Hi all, I'm in need to put new front discs on but wanted to put in drilled discs, can I do this seeing as I don't have the sports package? ECP don't seem to have them for standard models..
You should be able to get drilled discs for most cars but you may have to go aftermarket like black diamond or brembi to get them but the problem with drilled discs is the pad wear will increase and they can crack around the drilled holes do you need to uprate them or is it just for cosmetic reasons ?
C270cdi Av (Gone) CLK500 Avantgarde (Gone) SL500 (R230)
I bought 4 Mtec discs when I had my 2003 CLK500, fitted them myself & they were better than the standard discs, I would/will happily buy from them again.
