Codger49
- May 21, 2015
- Location
- South Kent
- W209 CLK500, W168 A190; E46 325i; SPA2 XC60
Something is not right here (an obvious statement!).
I would contact MB Guildford directly to verify the parts fitted are correct and properly installed.
Other questions I would ask:
Did your indy replace the 'electroplate' (RS CTRR. ELECTROHYD.) as well as the valve chest (VALVE GEAR/CTRR. UNIT ELECTROHYD.)
Did your indy source the parts from Mercedes?
Have you been given the part numbers?
What was the stored fault code?
Was the stored fault code cleared before the software update was applied?
Answers to some or all of these questions should help an experienced technician (a la Olly) to give you guidance.
