There is a drain which carries water from the very far right of the windscreen drainage channel which is blocked (right-hand side viewed from inside the car)
The water goes from the screen, run into a channel close to the bonnet hinge before going into a down-pipe next to the fusebox which discharges the water. The channel is clear but the pipe is blocked, which is causing water to back-up and run to where it shouldn't - inside the car.
Problem is I can't see how to access the pipe to unblock it
Is there a way of unblocking it from the top, or can it only be done working from underneath?
Many thanks,
Dave
Many thanks,
Dave
