Hi, a friend of mine has a w209 clk and recently the passenger headlight started flicking and eventually went out. We went to go change it and found the actual connector and bulb had melted! Has anyone actually seen this happen before?
The bulb was recently changed 3 months prior to this with a non-oem bulb from a well known motor factors. Is this due to using a non original bulb or is the ballast going bad?
Regards
Regards
