Hi everyone!
Help with WIZ needed pls the rear offside brake line gone rusty and started leaking jacked it up and was thinking to replace the both rear brake lines to the rear calipers. At this stage it looks to me I need to drop down a bit or remove the petrol tank? Drop down a bit or remove the rear subframe? My old computer is down and cant access the WIZ. Can anyone help me please with the method from WIZ or if you know the best way to do it pls.
Thanks in advance
Sent from my BKL-L09 using Tapatalk
Thanks in advance
