W209 Door Mirror Indicator Replacement
stats007
Hampshire
575M
Am I right in thinking the mirror glass needs to come off before you can unscrew the LED indicator unit? If so does it just pop off or do you need to release a spring clip behind it?
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
Release the glass at the top. It will be clipped in. be careful as it is easy to smash the galss.
OP
OP
stats007
stats007
Hampshire
575M
By release you mean pull? I've done this before on the R129 - however you could dip the mirror down to expose the spring clip which could be released with a hook.
rf065
Grossbritannien
SLC300 - C250d Estate 4 Matic & Z900rs
For reference pull and lift slightly:
Those instructions are for a W209 after 29.03.04
Before that date the lens is removed by pushing a clip hidden behind the lens on the outside edge. (Left or right of lens depending on what one you are doing)
Russ
lynall
Kent
The silver one.
My 210 also had double sided tape between the mirror and the black plastic mount, right bugger to get off.
Lynall
OP
OP
stats007
stats007
Hampshire
575M
That's usually a sign that it's been broken before.
