Hello all
Now that the weather has improved, it is time to do a bit of maintenance on the car.
I noticed that when I opened the passenger door, a bit of water was coming out from the drain holes on the door. Taking off the interior door card revealed that I had a leak which I found was down to the weather shield being torn as per pic below.
I have purchased a new rubber shield and before I attempt to change this I wanted to see if anyone had done this before and whether there was anything I need to be aware of or any hints and tips. It does look pretty straight forward but I want to make sure I do not break any of the clips etc as the new part does not come with these.
Second question, has anyone ever attempted to repair the rubber and if so, has the fix lasted?
