dockermel
the headlights on my w209 are all yellow and foggy, has anyone had this problem and tried any of the products on the market.???
I had the same problem so used Meguiars headlight kit:
Photos.
Before:
After:
Before:
After:
I can even seen the 'Mother of Peal' effect once again:
They were bad enough that I wanted to do them.
The op said his lights were yellow and foggy so i doubt mequirs would do much as yours were slightly hazy. Plus you have clear lights so its not that bad at all.
I have the same clear headlights as the OP. Im sure the kit I bought would bring his back with some elbow grease.
scares the hell out of me, taking drills and sandpaper near my car ;o)My car suffered with the same problem, & I bit the bullet masked around each headlight, then using 600 grt wet &dry and a little sprayed water sanded the headlight plastic followed by 1500 grt and finally t cut using a Halfrauds buffer on a cordless drill. Finally polished with Megs plastic polish.
Perfect !!!!!!!!!!!!!!!!!!!
