Aswall
I know i've asked this before but I thought I'd try again to see if anything new has come to light. I'm looking for a fascia adapter so I can remove the Audio 10 and replace it with a DIN sized Alpine unit and am not having much luck. I thought that my best chance was to look for one for a W203 as the centre console looked the same as mine and have found the following
1) a W203 plate with DIN size hole but with a blanking plate where the cubby box would be
2) a W203 plate with a DIN size hole and cubby box about half the height, making me think maybe the W203 isn't the same as mine
3) an adapter described as "2002 230 coupe" on www.autotoys.com that does look the same as mine.
I am slightly baffled by this last one, I thought the 230k engine had been removed from the range and replaced by the 240 so is this referring to an old shape CLK or is the 230 engine still made in the little hatchback C class?
I'm a bit dubious about ordering from the US, especially as I can't tell whether any of these would fit. Are there any places in the UK that are likely to be able to do these?
Hasn't anyone with a W209 or W203 changed to a DIN size stereo?
I've trawled the internet using every possible combination of words and would be grateful if anyone has found something I have'nt
Cheers
Andy
Cheers
Andy
