W210 300TD Air Charge ditribution tube
Discussion in 'Engine' started by mbooty, Sep 1, 2011.
  1. mbooty
    mbooty New Member
    1
    Mar 20, 2008
    What is the sequence to remove the inlet manifold on my 1999 300 Turbo diesel. I need to get at the fuel pipes ( Leaking). Have removed the Torx bolts from the top, Do I remove the 4 female type torx underneath and if so how:wallbash:
Share This Page
