W210 320 cdi. Black smoke. Limp mode.
renault12ts
MB Club Veteran
2005 W215 CL500.
The alternator and water pump have been replaced. Last week, the alternator pulley fell off, but the bearings were also shot. And the water pump was leaking. So, one brand new (used) alternator and water pump etc...£409 fitted and the car is back on the road.
BUT...the car is spewing out large amounts of black smoke and is in limp mode. This is nothing to do with the alternator etc, just bad luck. The garage tested the injectors and they are fine. The MAF is only 18 months old, and they have discounted that.
All suggestions gratefully received.
Dieselman
Banned
Peugeot 403 Convertible
Buy a 300TD, they don't give all this hassle.
Check the usual suspects, EGR valve jammed open, turbo vanes jammed, boosted air pipe blown off, leaking inter-cooler, blocked Cat.
OP
OP
R
renault12ts
MB Club Veteran
2005 W215 CL500.
I will. Now,how do I do all that?:eek:
Dieselman
Banned
Visual check for the blown off pipe and inter-cooler, try sucking on the EGR vacuum pipe as a test of the function of that, disconnect the exhaust to check the Cat.
OP
OP
R
renault12ts
MB Club Veteran
2005 W215 CL500.
So checked the IC pipes...all intact.
Had the vacuum pipe to EGR disconnected...not sure what I should be experiencing when sucking ??
