braces1977
thanks so far for all your help
jumped in the car this morning and the car was fine it pulled away like it should left the lad in his fto thinking he was still in reverse,
then i slowed down for the roundabout went to pull off and there was no power again
the car has been on the computer and hear are the faults its showing up
please help anyone i am at wits end
p1665 = elec heater booster equip
p0703 = brake signal plausibility 2
p2204 = external quality control by etc read fault memory of contol unit etc
p2204 = +tcm
p1330 starter control open circuit
p2203 = esp system fault
p0500 = vehicle speed signal the ? data are invalid
p1615 = common rail direct inj cdi control module supply voltage readout too small
p0600 = can fault the databus is faulty
p0600 = can fault the transmitter is faulty
p0100 = bank 2/5 hot film mass airflow senor the signal voltage is too low
p2204 = +tcm
