stuboy
Hi Chaps
Looks like i'm in limp home "ish" mode?
Symptoms are:- wont rev above 3000 just like a limiter, car works fine below 3000revs and I'm still getting about 11km/litre on a run so i am guessing my MAF is ok? I have another one i can swap in.
Where is the air temp sensor? could be that?
Just had the spark plugs out, what **** designed where they are situated and the stupid plug caps that won't come off without you either breaking your fingers or breaking the leads!!!!! Anyhow they have bosch F8DPER platinum plugs, ohhh classy and they have a 1.1mm gap which i believe to be correct? Am sticking them in my Ultrasonic as i have em out, they look lovely and cheast nutty just like they should .
Any ideas most welcome
Cheers
Stuart
Cheers
Stuart
