Well chaps and chapesses had the joy of swapping the alternator out today due to it doing whatever bad things alternators do to them selves.
Easy hour or 2 says I. Car says oh no sir I'm much to specially and have a fancy water cooled jobby that will take hours upon hours of your attention and skin and your best swear words.
So after phoning merc and finding they want 900 beer tokens just for the unit, fuq dat says I and find a recon one with 12 months warranty for 116 beer tokens and free next day delivery.
To some up the procedure if anyone else is feeling dull enough is
Disconnect battery
Drop under tray and drain coolant
Disassemble air box ducting and water pipes in the turbo area so you can access all bolts.
Undo bolt under cylinder head to the water pipe from the alternator.
Undo alternator and pull it out from underneath and rear.
Water pipe just pulls off.
To get to the belt tensions if you can't remove the fan a 17mm spanner from underneath is easiest.
When coming to reassembly connect the water pipe to the alternator and head before bolting lithe alternator back on. (Ask me how I know)
Also the o rings on the pipe. Change them. They are 3 squid each from dealer. I didn't and when I refilled the coolant it ****** all back out again.
Hope this helps
Disconnect battery
Hope this helps
