W210 bonnet partially locked
muhandis89
Majorca
E320CDi Estate
Gents,stupidly I have managed to low the bonnet with a small(flat)toolkit inside.The bonnet's partially open on the driver's side,but the lock appears to be engaged,and I can't shift it.Does anyone have an advice please?
B Rgds
You can try pulling the bonnet release while some one leans on the trapped side. If that doesnt work you might need to ask leemanuel for advice as he has just had a similar problem:
Link
Thanks.Will try that and revert.
Dear GazCaff.Worked a treat.Found 2 friends in the pub,to help.Worked perfectly.Bonnet now back in correct place.Many Thanks
