Hi.
Anyone know where I can obtain the microswitch for the boot lock on a 2001 W210 E320 CDI Saloon?
Just replaced the boot lid and all was working including remote lock/unlock. Closed bootlid just before lunch and couldn't reopen it using remote later on.
Vacuum not operating to the lock, although it has since I replaced the bootlid. Swapped the pipes into the pump and it operates at the lock hence I'm thinking there is a signal missing somewhere!
Turns out the microswitch fitted to the boot lock is intermittent. It appears the microswitch closes when the lock button is pressed in and signals to the vacuum pump to operate?
So, where to obtain the microswitch? It appears that the boot lock does not come with it ready fitted.
Many thanks.
Regards
solarmer
Many thanks.
Regards
solarmer
