w210 brake judder
AlisterJames
Hi
Wonder if anyone has ever had this problem on a w210 e class320cdi?
The pads and discs are fine but when braking there is a juddering?
Very occasionally(once a month maybe) the abs warning light comes on but then goes on startup.
Any thiughts would be appreciated
Alister
If the rear brake calipers are the dual-piston type - Check for seizure of one side of the caliper.
You can go some time without noticing it.
It may even pass MOT tests.
Eventually, the symptoms you describe can occur.
