datripsta
Does anyone know the full load drawn from my alternator if all electricals are drawing current and the capacity of the current cable from alternator routed through what ever systems to the battery. I see a 200 amp fuse which suggests its ~190 amp capacity ?
I've seen 190 amp alternators on ebay sold factory fit options but not sure if they fit on the OM613 engine in my car.
Im looking to see if I have any spare capacity to upgrade audio system. Car has an amp but I believe its non bose. I'll be installing a new audio set up. New cables ,speakers, amp, head unit ( probably going with Nexus 7 gen 2 tablet with USB DAC as head unit ) etc... factory audio equipment will be disconnected or removed including Comand 2.0 unit, hands free phone and linguatronic.
Not bought any replacement bits yet and not looking to go crazy but want to ensure I don't kill the electrical system if I run an amp which needs 60 amps peak which in reality is easily done with a 5 way amp output to a 4.1 system. That said i'll probably never get to pulling full power but maybe running system at 50% more likely. A good number of quality amps on ebay going for reasonable money and these quality maps do pull a fair few amps even at 50% use.
I did the maths on a 2 amp system. One for sub and the other for all 4 door speakers run in active x-over config ( 4 mids 4 tweeters ). I calculate a 120 amp load! I then decided dissipate the cost being within rage if I buy used quality amps its way OTT for my needs. Thats what got me to thinking its easier to work back from any spare capacity the alternator has and tailor the system to the capacity.
Car is 2001 Estate E320 CDI Avantgarde.
MB online EPC Shows 150 amp alternator fitted to my car. I read 150 would be the cold output and can't find the hot output value which would be the best starting point.
Things installed that might not be standard that draw current:
Climate Control unit
Electric Sunroof
Electric, heated, cooled, contour seats both driver and passenger
Xenon Lights
Auto Dim mirrors
Parameter Steering
Parktronic
All interior bulbs changes to LED
Sorry for the long post and I hope I got all the detail down to answer any questions.
Thanks as always
DT
Electric Sunroof
Xenon Lights
Auto Dim mirrors
Parameter Steering
Parktronic
Thanks as always
DT
