w210 CLimate illumination?
tuscan_al
Middlesex
S210 e430, w126 500se
I drove the car tonight for the first time and it seems the lights (IF any) for the limate are not working, I have the red ones for which buttons are pushed but the LCD has no backlight, should it? And how easy a bulb to change if so?
It should have a backlight. Pretty sure it's LED(s) and not very bright when it is illuminated.
Thanks, I will see how it removes and go from there.
Its not LED. The unit is removed just as you would the radio...with keys in the two slots. There is a bulb in a holder on the underside.
You say LCD display so I assume you have digital climate control in which case there is just 1 illumination bulb which is very easily changed with the MB removel keys. Go to your local dealer and get the following:
Bulb - A 002 544 02 94 - £1.56
Removel Keys - W 000 589 88 63 00 - £1.13
The climate panel takes less than 10 seconds to remove with those keys and the bulb is on the underside of the unit.
