W210 Command from germany
PeterE320Cdi said:
This looks tempting as they say that returns are accepted for a month so I would have a chance to get it tested.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120066052298&fromMakeTrack=true
Now if I can only find a second hand fascia panel :)
Be careful.
Firstly the picture is not an A210 unit its an A208. Second you would be much better off getting an A210 820 54 89 or an A210 820 56 89 as these are newer units and will most likely have my01 on already (the 56 89 definately will). there are a number of 48 89 unitd around thet are non-canbus types. You need a canbus model which the 54 89 and 56 89 unit are.
Remember you will need a loom adapter or some skill with pins and a soldering iron, a teleatlas disk, an antennae, a replacement fascia and a monting frame also.
Good luck.
