W210 e220 cdi starting issues.
bigp271
W210 E220 cdi Elegance
Hi guys. I've been lurking for a while and I must apologise for going straight in with a help post!!
I'm after some technical advice.
Been having a starting issue with my e220 cdi. If the car is parked facing up hill overnight then it normally takes ages of continuous cranking to get it to start. Parked facing downhill it's fine.
Did some digging on the tin-ter-webs and it would appear the fuel is draining back to the tank as there's air getting in somewhere. This only started happening after changing the fuel filter.
I had also read that this could be due to leaking pipes or O'rings?
Or does anyone have any other suggestions?
Could someone perhaps clarify which pipes and or O'rings this could be?
Any help greatly appreciated as it's getting on my nips now!!
Paul.
Been searching through old posts on here but I'm still not sure which pipes to order. Can anyone shed any light on this?
Also keep reading about o rings. Are these on the injectors themselves?
Any help would be most appreciated.
The O rings are on the ends of the fuel lines and HP fuel pump.
On the 320 the fuel lines are clear pipes, not sure what they look like on a 220
Thanks Bob. I'll see if I can find some part numbers for the lines as knowing my luck the buggers will be brittle and snap!!
If you give me your vin or reg I can have a look for you
That would be hugely appreciated bob.
SY03DZD
I assume it's all the plastic fuel piping around the front of the engine I need.
Again many thanks.
I would say no.113 Part no. A6110707232
Here's your datacard whilst I've got it up
Datacard
Identification number: WDB2102062X078674 7
Chassis
Sales designation: E 220 CDI
Order number: 0 2 537 19025
Delivery date: 29 03 2002
Paint code 1: 744U BRILLIANT SILVER METALLIC
Equipment: 451A CLOTH ELEGANCE ANTHRACITE
Engine no.: 611961 40 078640
Transmission: 722699 03 543682
SA code
205B OWNERS MANUAL AND SERVICE RECORD - ENGLISH
221B SIGN COOLANT/REFUELING - ENGLISH
236B WITHOUT CUSTOMER SERVICE - STATION INDEX
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
345 RAIN SENSOR
423 5-SPEED AUTOMATIC TRANSMISSION
450A FABRIC-ELEGANCE
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
480 SELF-LEVELLING SUSPENSION
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
537L GREAT BRITAIN
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
550 TRAILER COUPLING
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
584 ELECTRIC WINDOW REGULATOR
5XXL EUROPE
600 HEADLAMPS - CLEANING EQUIPMENT
611 EXIT LIGHTS FOR DRIVER DOORS
613 HEADLAMP LEFT-HAND TRAFFIC
641 LIGHT ALLOY WHEEL, 11-HOLE DESIGN
668 PACKAGING FOR SHIPPING VEHICLES WITH TIE-DOWN HOOK
673 HIGH-CAPACITY BATTERY
802 AEJ 01/1/X
819 CD CHANGER
833 INVALID/GREAT BRITAIN,ADDITIONAL PARTS
844 FOLDING BENCH SEAT IN CARGO AREA INCL. 2 AUTO -
876 INTERIOR LIGHT ASSEMBLY
877 READING LAMP IN THE REAR
882 INTERIOR SAFEGUARD
910 DYNAMO WITH HIGHER CAPACITY (FFO)
955 EQUIPMENT PACKAGE ELEGANCE
984 COC DOC., DELETION OF VEHICLE REGISTRATION DOC.
989 IDENTIFICATION LABEL UNDER WINDSHIELD
M002 210____ - 19960904 - ENGINE WITH EXHAUST TURBOCHARGER WITH INTERCOOLER
M002 611.9__ - 19960826 - ENGINES WITH EXH.TURBOCHARGER WITH INTERCOOLER
M002 722.6__ - 19960119 - ENGINES WITH EXH.TURBOCHARGER WITH INTERCOOLER
M22 DISPLACEMENT 2.2 LITER
M611 R4-DIESEL ENGINE OM611
Edit time ran out so this one too
and then 149, part no. A6110706332 and 125, part no. A6120703232
Bob I honestly can't thank you enough mate. Really appreciate it.
I'll let you know if this cures the problem.
bob6600 I was hoping to pick your brain again mate! Sorry to be a pain!
I was doing some further digging through the forum and Google and found a few people mention the fuel filter housing having seal that can fail and draw in air. Since this problem only started after changing the filter I thought it might warrant further investigation?
Also are the fuel line O-rings 10x3 mm?
Again any help is hugely appreciated.
Again huge thanks Bob.
