W210 e220 intake air temp wiring
Discussion in 'Engine' started by Harlowcabbie, Apr 26, 2014.
  1. Harlowcabbie
    Harlowcabbie Hardcore MB Enthusiast
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    An anyone out there please either take a photo or just let me know what colour the wires are going to their intake temp sensor. The reason I ask is I have two plugs in that area and am not sure which one is meant to be used. ive been to an indie and he has plugged one in just not sure it's correct .i have tried swapping them around and the car drives seemingly ok with either one used. I have scoured the net for hours and cannot find anything to show the sensor and wiring or any clues as to what the extra plug should be for. Would really appreciate it as it's driving me nuts not knowing if it's right or not.
  2. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    I'm guessing nobody has a w210 model then that could have taken a quick look at there's.
  3. E270 Owner
    E270 Owner Hardcore MB Enthusiast
    1,672
    Dec 23, 2012
    S E London
    Car:
    Anything I get my hands on.
    Show us a pic of the two plugs your talking about.
  4. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    These are the connectors
  5. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
  6. StevenN
    StevenN Hardcore MB Enthusiast
    437
    Sep 12, 2010
    Nottingham
    Car:
    E220 CDI 2002 W210 Auto
    Mine is a 2002 reg
    Can go look see if you give me more info
  7. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    Would really appreciate that it's the air intake temp sensor on the solid pipe from the intercooler upto the egr valve. Sensor on the left of the pipe is the map on the right is the one I need info on. Just the colour of the wires going to it would be great .
  8. StevenN
    437
    Sep 12, 2010
    Nottingham
    Car:
    Not sure if this is the bit without taking the engine cover off
    But the plug has a brown wire and a green and red wire
  9. StevenN
    437
    Sep 12, 2010
    Nottingham
    Car:
    A wider angle
  10. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    No mate wrong part if you look to the right hand side of your engine at the front you will see a black hose coming from the engine cover down to the intercooler it's immediately left of the windscreen washer bottle . The hose has 2 sensors on it one on the left one on the right it's the right hand side sensor I need info on . Thanks again
  11. StevenN
    437
    Sep 12, 2010
    Nottingham
    Car:
    I would look to check which way round they are but mine have broken off.
    Bet this is why your asking
    I can only thank you. What's busted?
    Brown&white
    Green&white
    But which way I dunno????
  12. StevenN
    437
    Sep 12, 2010
    Nottingham
    Car:
    Just re-read your post.
    It looks like we can both help each other on this.
    All I need to do is figure out how to fix mine as the wires have broken at the plug.
    It looks line they actually run along a washer pipe
  13. StevenN
    437
    Sep 12, 2010
    Nottingham
    Car:
    My car has been running a bit rough with erratic idling so perhaps this is the culprit?
  14. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    It adjusts the air fuel mix depending on the temperature of the air going into the engine .this is what I have been told supposedly without it the car defaults to a certain temp range and may possibly use more juice than normal . If I'm wrong someone please correct me
  15. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    You should be able to use my first pictures to work out which wire goes where by the orientation of the plug. And yes I believe it may cause erratic idle .
  16. StevenN
    437
    Sep 12, 2010
    Nottingham
    Car:
    Mmmmmm
    Perhaps it's right
    I'm averaging 42mpg on the 12mile daily commute.
    So it ain't bad but I've known better
    To think if you had never asked I would have never have found it
    Cheers
  17. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    Looking at your picture if those wires were connected same way they are now it would be correct
  18. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    Np ty you've put my mind to rest as well
  19. StevenN
    437
    Sep 12, 2010
    Nottingham
    Car:
    No can't quite figure out which way.
    When you've fitted yours, er can you take a picture?
    Ta
  20. OP
    OP
    Harlowcabbie
    163
    Jun 19, 2012
    Car:
    Mercedes e220 w210
    As you look down at the sensor green top brown bottom. Or green closest to engine brown closest to radiator .
    1 person likes this.
Share This Page
