W210 E300 Alternator pulley woes
chesterpiglet
Mercedes W211 E280 Cdi Sport Estate
Hello everyone.
I posted last year when I had fuel problems which largely due to the advice given on here were solved.
I am in France at the moment and due to come back on Tuesday when disaster has struck.
Last Sunday there started a squeak from the front pulleys area of the engine.This got worse over the coming days resulting in the alternator pulley wheel totally coming off today.I stopped pretty quick and the water boiled briefly but doesn't appear terminal as the car starts ok.
A friend who used to work for MB but a long time ago has had a look and when you put the pulley back on the shaft it really wobbles about and is knackered.He thought as there was the remants of a rubber seal he wondered if there was a rubber insert that has totally disintegrated.
Can I just replace this insert(if indeed there even is one).
Can I just replace the pulley?
Has anyone got a good used alternator or even an old one that I could get the pulley off?
I have seen alternators on Ebay for around £150 are they any good?
The no.on mine is a Bosch 115 with nos 0 123 510 080 and 010 154 9402 on it.
Also on any tips on how to get the alternator off.I can only see one MB hexinut on the top and I can't feel any others underneath.Also space seems quite restricted,is it a radiator out job or is there a trick to it.
If anybody is willing to chat to me about it I can phone them back from my landline to a landline.
Any help would be gratefully received as I am stuck.
Many thanks in anticipation
Regards Rob
What about nearest mb dealer for a new pulley, or maybe easier to order one from the uk.
Lynall
Модель=606962 Каталог=19T Система: 15 ELECTRICAL EQUIPMENT
Иллюстрация: 030 Узел: ALTERNATOR
№КодЗаменаК-воВар-тНазваниеИнформацияПримечания400 0101544802 001 ALTERNATOR WITH FREEWHEEL 12V/90A; BOSCH *019 *697400 0101549402 001 ALTERNATOR WITH FREEWHEEL 12V/115A;BOSCH *020 *697410 0019902920 004 SCREW DRIVE END BEARING 415 A00798124250079818925 - BALL BEARING 415 0079818925 001 BALL BEARING DRIVE END BEARING 420 A00798125250079817325 - BALL BEARING 420 0079817325 001 BALL BEARING SLIP RING SIDE 425 0001540657 001 RING SLIP RING SIDE 430 0021549206 001 REGULATOR AND CUT-OUT 435 914026004105 002 COMBINATION BOLT REGULATOR AND CUT-OUT M4X25 450 A00015427040001543404 - COVER 450 0001543404 001 COVER FOR ALTERNATOR: 70A/90A 450 0001542904 001 COVER FOR ALTERNATOR: 115A 455 0069903201 003 SCREW COVER 460 0019901421 004 SCREW HOUSING 503 6041500060 001 PULLEY WITH FREEWHEEL 506 0001550902 001 COVER TO 604 150 00 60 510 0009902250 001 NUT PULLEY TO ALTERNATOR 800 6031500470 001 SUPPORT ALTERNATOR 803 6019920425 002 SLEEVE 809 914007008042 004 COMBINATION BOLT SUPPORT TO CYLINDER CRANKCASE M8X40 824 N914126010021910105010043 - SCREW 824 N910105010043910105010044 - SCREW 824 910105010044 002 SCREW ALTERNATOR TO SUPPORT M 10X90
*019 UP TO ENGINE: 11/97
*020 FROM ENGINE: 11/97
Alternator woes
Hi all
Thanks for the help received.I have ordered a pully wheel initially in the hope that the shaft isn't too worn.It appears that the alternator is fixed.How do you tension the belt?I presume there is a tensioner somewhere else.The car has aircon if this makes a difference.
Many thanks again
Regards Rob
Hi all
Many thanks again
Regards Rob
Tensioner is on the head, you need undo the 13mm and used a 3/8th bar through the hole to release the tension.
Hi all
Many thanks again
Regards Rob
Hi Rob AKA Chesterpiglet
I wonder if you resolved your pully problem? Did you replace the pully or the complete Alternator?
I appears I have the same failure.
Cheers
JTP
I decided to buy a new one, for just over 100 more. It has yet to arrive here in Vienna, so I can't say if all is fully sorted. The fitting may be wrong - they may have sent the wrong item. Dunno till it gets here - sigh.
Thanks for asking :-)
Blessings
JTP
