W210 E320 CDI Estate Noisy Front suspension
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by jon_viola, Sep 20, 2011.
  1. jon_viola
    jon_viola Active Member
    289
    Apr 3, 2007
    Sussex
    Car:
    S212 E350 CDI Aantgarde Sport Estate
    Hi I have a E320cdi Est and the front suspensions started clonking and making a lot of noise generally. Could anyone advise me of what to do about this?
    Also the glow plugs need doing- are there any particular brand that work well?
    Many thanks
    Jon
  2. renault12ts
    renault12ts MB Club Veteran
    16,122
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Check:
    Anti roll bar (ARB) bushes.
    ARB drop links.
    Lower ball joints.
    Track rod ends.
    Inner bushes of top and bottom suspension arms.
  3. OP
    OP
    jon_viola
    289
    Apr 3, 2007
    Sussex
    Car:
    Thanks for this- can the bushes be replaced alone or do I need to buy the suspension parts too? What would I order say from German and Swedish? Anyone got any part nos?
  4. OP
    OP
    jon_viola
    289
    Apr 3, 2007
    Sussex
    Car:
    My garage has checked all the bushes etc and found no problem. Any other ideas as to the source of the noise?!
    It seems to be the N/S/F mostly......
  5. Stratman
    Stratman MB Enthusiast
    4,724
    Jun 15, 2003
    Sunbury
    Car:
    W203 C200 CDI '04Estate
    It could be a broken spring. They can crack near the end of the coil inside the support cup and can be easily missed unless you're specifically looking for it.
  6. Dichtung
    Dichtung Active Member
    292
    Oct 16, 2007
    N.W.
    Car:
    W203 2.2Cdi
    Check tightness of bolt that secures bottom of shock to lower suspension arm.
    If this has become slack for any period of time, the holes in the vertical lugs will have worn oval, and the sound travels up the spring to the body.
    2 people like this.
  7. Dichtung
    292
    Oct 16, 2007
    N.W.
    Car:
    W203 2.2Cdi
    And use GENUINE Beru glowplugs.
  8. OP
    OP
    jon_viola
    289
    Apr 3, 2007
    Sussex
    Car:
    This is exactly what it was! Now I just have "squeaks" as i go over a speed hump with no rattles.
    Much better- thank you!
    1 person likes this.
Share This Page
