Dave K
My E320 CDi has destroyed a MAF within 1.5 years of replacing it. Ho hum. MB read the fault code out and confirmed my suspicions. They even tried another MAF to see if the situation improved..and it did (revs above 3000 and has low down grunt again). But, even with the new MAF fitted, it's still chucking out a fair bit of black smoke. It also suffers a sort of tinkling/clattering noise from the engine (although it can't be heard when revving in neutral or park - must need some load). MB reckon either blocked catalyst, clogged injectors, or faulty EGR. I've tried Millers to cure the tinkling/clattering (it's been going on for quite a while) but no perceivable difference. Do these injectors respond well to proper off car cleaning (ASNU type machine) or is replacement the only answer? Does anyone have any experience of the EGR system on these cars? I'd imagine replacement is straightforward but can it be blanked off (rather than disabling the actuator which would throw a fault code)? I expect all this will become apparent once I get stuck into it but just doing a bit of homework before unleashing the spanners on it.
