I have had starting issue that has got progressively worse for 6 months and a constant smell of diesel from the engine. I had all the fuel return pipes replaced a year ago. Overnight the fuel seems to drain back to the tank as it taking 1 and half ignition cycles to start from being parked overnight facing uphill.
The car finally broke down on the motorway after losing an extra gallon of fuel in 20 miles and failed to start again. Fuel seems to be the coming from the front of the engine and is coating the radiator and drive belt. When attempting to start the engine it is acting like it is starved of fuel and the drive belt is not turning the pump on the lower left of the engine due to the diesel covered belt (I assume this to be the coolant pump).
Question's
1) what is the top 'pump' type device that is driven by the drive belt that has fuel lines coming from it and is this know to develop leaks. This area seems to be the source of the leak but it's not at the junctions with the fuel lines.
2) Are there are any other know leak points at the front of the engine?
Question's
