growlygrowler
- Aug 20, 2009
- 1990 500SL
Hi all,
My first post on this forum.
The car is a 545,000 mile y2000 "W"reg E320CDI estate that I bought cheaply from a taxi company. My wife thinks it's cool that it's been to the moon and back and I'd like to fix it up for her.
Here's the problem:
The car starts up fine though occasionally misses a bit at mid-revs. There's no smoke at tickover and I can rev it to the red line standing without any smoke.
After a few minutes on the road the car goes into what I assume is limp mode (max revs 3k standing, 2.5k on the road) and it's slower than a very slow thing with "slow" written on it. It will gently gather speed to 70 no problem, but with some black smoke.
When it's working ok it pulls fine and I can red-line it though produces black smoke at high-ish revs under acceleration.
The local garage found an EGR code in the memory and broken vacuum pipes to the EGR. I also got an EGR actuator and we fitted that. Problem persists.
When I first got the car, the headlamp height adjust (halogen lamps) didn't work, so I assume there is (or was) a vacuum problem?
I had the same problem when I drove the car about 400 miles home, though after a bit of injector cleaner in the tank and 100 miles into good run it seemed to clear itself. The smoke persisted however.
I don't know when the injectors were last cleaned but I can get these checked locally. Would a leaky injector or two cause the limp-home mode, though?
Am I wasting my time and should this thing just go to the nearest scrapyard? Anyone got any ideas?
cheers
Dave
Here's the problem:
cheers
Dave
