aka$h
Ive had this on my estate since buying it which was 8 or 9 months ago. Whenever the kickdown switch is used the car will stop reving at 2.8-3k and the waring "EL. POWER CONTROL" is displayed. This will clear after the car is turned off and restarted. The only fault stored on DAS is "B37 (Pedal value sensor) signal is too high".
I replaced the pedal sensor yesterday and the fault is the same. The fault can be reproduced when the car is in park too. But if full throttle is used, without engaging the kickdown switch there is no fault.
Anyone had a similar problem in the past?
