Hey guys ive owned a W210 E55 AMG for few months now its been great to me from the start so ive replaced few parts on it from the start so to say regular maintenance..... Then few months later started having a lot of acceleration issues i literary thew all of these parts at the car:
Bosch Iridium Spark Plugs New OEM
Brand New All 4 Tires...........
Belt Tensioner Replaced OEM Mercedes
Belt Replaced OEM Mercedes
Idle Pulley Replaced OEM Mercedes
Back and Front Struts Replaced Bilstein OEM
Brand New Tie Rods OEM Mercedes
MAF sensor Replaced (Mass Air Flow Sensor) OEM
TPS sensor Replaced (Throttle Positioning Sensor) OEM
Transmission Flush Done all Filters replaced Electronic connector replaced
Torque Converter Drainer and Replaced with new fluid
Water Pump Replaced BOSCH OEM
Brand New Power Steering Rack OEM Replaced !
Air Conditioning Refilled.....
Air Filters Been Changed Kleeman OEM
Carbon Fiber Dash Wrapping Whole Central Console !
Brand New Motor & Transmission Mounts!
Brand New SwayBar Bushings OEM!
Brand New Rear Control Arm Kit OEM!
Brand New Set of 4 Subframe Mounts OEM!
Brand New Wheel Hub And Bearing (Front) 2 OEM!
Brand New Rear Bearings Replaced (Rear) 2 OEM!
Rear Differential Fluid Changed
Valve Gasket Covers Replaced OEM!
Spark Plug Wires Replaced OEM!
BG44K Used to Clean the Fuel System !
Fuel Pump Replaced OEM! Bosch
Fuel Filter Replaced MANN OEM!
Emergency Brake Replaced with New Parts!
Brand New Brake Pads Installed!
Shift Leveler Replaced with new Selenoid OEM!
Vacumm Hoses Replaced Brand NEW OEM!
and after all of this even tho half of these things have nothing to do with the problems im having just an overly obsessive maintenance since i like to take care of all my cars i cant figure out what to do the only 2 things i still havent tried yet was the O2 sensors and the catalytic converters.............. can somebody help me try to figure this out ive been on a lot of american mercedes forums and even the dealer and non of them can figure out whats wrong...... if anybody have any insight on this please help !
