Can someone tell me where about the wiring comes inside the vehicle :?:
12N socket (with bypass relay)- where's the best place to splice into the lights
12S Socket (with auto split charge relay) - I was going to use fuse 12, as that is labelled up for trailer power supply, for the relay (fridge/battery). But pin 4 is for a power feed - would this be best to take from a seperate fused feed (one of the ones that aren't used)
Your advice would be most welcome
