w210 estate rear door noise
2117kh
LIncoln U.K
r107 350sl
Hi All
I have , as they probably all do, self closing mechanism in rear door of my estate.
When you close it should it sounds like somethings fell off?...it works okay but sounds awful...no mercedes clunk here, more of a clank..difficult to describe exactly but it happens every time
any ideas?
E320 CDi Estate
I have to admit that mine is a W211 but that does not sound good to me. Has it just started doing it or is it something you have suffered for a while?
OP
OP
2
2117kh
LIncoln U.K
r107 350sl
re back door
Hi
I have had the car since january and it has always done it..sounds like something has fallen off when you shut the door, like a plunger...works okay but its like there should be a buffer or something for the mechanism to strike if thats what it does..I really dont want to take it apart unless there is a known cure because that tailgate panel is a b###ch to get back on again. This is from experience after repalcing washer pipe a couple of times.
thanks for your interest kh
Harrythedog
Tynemouth
GLC 250 Sport Premium+
Hi All
any ideas?
Mine reminds of the sound you use to hear when you put a video tape into the machine but it works fine
renault12ts
MB Club Veteran
2005 W215 CL500.
See post 2...it's normal. I've had 2, they both sounded the same.
