As above you should be able to fold them in manually, though if they are partially seize they may resist, they are quite stiff when they are not seized. Once folded back you should see the pivot points, and you will need to douse these liberally with release oil, once free use some three in one oil. Give it a few weeks of use then cover with a smear of grease. You can do each mirror in turn.
