MOT time again..
Just replaced the front dampers on my e320cdi, the reason for replacement of the original OEM units was structural rusting and some oil leakage but still worked well at damping. (Plush, noise free riding of bumps and potholes.)
I have replaced the units with G*F Motor Factor supplied units and to be honest have encountered a problem. The units were supplied manufactured by AMTEK Although unheard of were sent as alternative to BOGE units (there was one BOGE on the shelf, another was ordered - Part unavailable so a pair of AMTEK units were supplied as book alternative (same price)) All part numbers were checked correctly for Elegance model and not Avantgarde.
These look very good quality units and fitted right on without issue.
Now when driving the car the slightest pothole during normal driving or 5mph speed ramp (I have now have to crawl over) there is a solid thump on passing over it. It is not any other component as they have all been done over time and the noise wasn’t there before the shocks were swapped.
As you may know there is very little free travel on the OEM units shaft before the compressible foam bump stop on the rod starts to compress (prob about 2 .5 inches of free travel at the most) The replacements have the same travel but compress to a very hard, almost incompressible, rubber stop and not the foam stop as the oem units. I am pretty sure that this is the issue and will be removing the dampers at the weekend to disassemble the AMTEK shafts and swap over the damper compression bump stops and upper rubber layout.
It shouldn’t be necessary to do this kind of mod to new units and I will report back as to how it went.
Anyone had similar with AMTEK or other brands? If not, a worthy thing to note.
In a real world we would all like to buy a set of OEM Sachs front shocks for over £150 but this isn’t happening - it would be 10 percent of the purchase price of the car!
MOT time again..
