W210 Front Subframe Change
The rust is caused because the under tray touches the cross member and retains water. A simple modification was to fit washers to the retaining screws to allow the water to escape.
Thanks Renault12. The o/s h/lamp nozzle was dry this morning but the tray was a bit damp as usual. I will def fit some washers so it sits a little lower from the subframe.
