W210 Gear Lever Moving When Under Load
rgracin
Essex/suffolk
2007 E63 AMG Estate
I've noticed this weekend that if a pull away briskly in my E430, the gear lever moves quite a bit.
My thoughts are that its worn engine mounts (Currently on around 145k) does this sound right, or could it be something else?
Gearbos was removed for a rear main seal replacement about 4k ago, but I don't think it's related.
I guess that you are talking about a manual transmission in which case if the mountings are gone then you will get the symptoms you are experiencing. Short of changing the engine mounts I do not know how you would prove this?
No, it's auto. When in drive, if I move off rapidly, the lever moves forward.
engine mounts - my 320CDI diagnosed [and cured] by Olly at PCS with same problem
