W210 headlamp wash leak - potentially expensive?
Discussion in 'Engine' started by jukie, May 22, 2012.
  1. jukie
    jukie Hardcore MB Enthusiast
    1,202
    Jan 16, 2003
    NE Cumbria
    Car:
    MY11 E350 CDi Avantgarde
    MY2000 E320. Water is leaking from the back of my off-side headlamp wash and draining the reservoir every time I fill it up. I can feel the leak and it's coming from something solid as opposed to a hose. It's dripping directly onto the "tray" underneath the radiator & pulleys, etc. Hopefully that gives people an indication of the location!
    Has anyone encountered a such a leak before? If so, hoe serious/costly might it be?
    TIA, David.
  2. ringway
    ringway MB Club Veteran
    6,715
    Nov 29, 2008
    In a World of My Own.
    Car:
    Audi A6 Avant 3.0 Bi TDI - A Fantastic Car! Range Rover Supercharged - Lovely! Also R32 & S4.
    The leak will more than likely be from the seal at the rear of the black torpedo-like jet units that spray the water on to the headlamps.
    I can't remember if the seal is an o-ring or not, but should be easily fixable with a glue gun or similar IIRC.
    1 person likes this.
Share This Page
