W210 ignition key will not turn
hifibloke
E280
hi
W210 2000 petrol
I can open the door via key but when in ignition the is no zip sound and key will not turn :(
I did not used the car much over past week and then few short trips
took the battery out (92Ah of some not well known make ) i don't know how old is the batt
anyone had this problem b4 ? what i can do/check ? :dk:
please help
Howard
MB Club Veteran
Toad Hall
CLS 500 / A 150
Possibly the EIS is dead. ( electronic ignition switch ) , you need it to go on a STAR machine to find out.
Dieselman
Banned
Peugeot 403 Convertible
Clean the red window on the keys and EIS, after that it's as above, the unit is kaput.
OP
OP
H
hifibloke
E280
Today I discovered a blown fuse 9 steering lock but after changing still no joy.
OP
OP
H
hifibloke
E280
I will check tomorrow with meter but I don't think this is down to battery.
OP
OP
H
hifibloke
E280
apparently you can not connect diagnostic tool if you can't turn the key ?
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
Yes you can.
The EIS is the only control unit the Star can communicate with with the ignition off.
samdogg
Stranraer Scotland
clk230 avantgarde,mazda mx5 hardtop convertable
Had this prob this morning with a low battery,the moment i jumped it the prob disappeared
toolman1954
Leven, Fife / Northampton
2003 320 CDI Avantgarde, 1997 312d Sprinter
I had a similar problem some years ago in my 210, my Indie diagnosed that it was the battery and because the battery was not so old, I was reluctant to buy a new one, however he was proved to be correct and a new battery cured the problem.
EZS
C36 AMG
No.
More than likely the ESL steering lock. If the fuse has blown then the Relay is caput. If the ESL does not dis-engage then it will not let you turn it!
Ian B Walker
Freckleton
300-24, saloon and coupe, E300 24 valve diesel estate
If you have had the battery off the EIS may have lost its memory. Put the key in the ignition lock and leave it for a time, it may just re learn.
Dieselman
Banned
No.
It would be worth tripping the lock released switch to see if the EIS then responds.
OP
OP
H
hifibloke
E280
Thanks for your help guys, car still on driveway as I'm waiting for my mechanic to look into this, it will be next week. If the steering lock caput what to expect money wise ?
BlackC55
£600 ish
E320 CDi Estate
£600 ish
Is it possible to buy and use one of these from a breakers or is there some sort of hard coding problem that will arise from using a second hand part?
