w210 injector pump outlet pipe seals leaking
tcr200
epsom
w210 e300 saloon
Hi all, I have a W210 with a leak from the outlet seals on top of the injection pump! Has anyone changed these seals themselves? If so what is involved? and do you need any specail tools?
Thanks.
Terry
search pump delivery valve seals....
you will find a guide
you will need a splined socket to remove the valves.
All explained in the guide
Hope that helps
thanks cant fimd guide at moment .off to work now ,will try later thanks again Terry
