W210 noisy aircon compressor bearing?
mellowman
Hi folks
I have a '97 230 Elegance estate which is producing a very noisy rattle with the aircon on, especially under acceleration. There is no noise under very light or no load, or a steady cruise.
I've been told it may be a bearing in the aircon compressor. is this expensive to replace and can it be done by any competent garage without specialist MB knowledge?
Thanks for any advice
M
If a rattle it may be the magnetic clutch, it is constructed of a few seperate moving components which rotate and engage / disengage, if a compressor bearing is at fault you will tell by using a long screwdriver or a length of hollow pipe hed against the compressor and then the magnetic clutch, the hollow pipe will amplify the sound and help to pin point it.
Thanks for the info Andy.
M
