Having sorted the alignment, my 1997 E320 W210 Avantgarde ("sports" suspension) is still not riding right, IMHO.
It wobbles/rocks from side to side far more than any car I've ever had before, it tends to twich out at the back when hitting a pot hole, and is far more "lively" than I expected.
Its handling is good - seems to be better the faster it goes, but the ride...
I am not sure whether it is :
(a) all perfect, but it's just the way it rides - low (ish) profile tyres, fully independent rear suspension, presumably no anti-roll bar (must get under when it's dry)
(b) knackered bushings (it has new shocks and a decent 4-wheel alignment)
(c) a rogue for some other reason
Tyres are Pirelli P6000s 215/55 R16
I've seen the odd other W210 look as if it rocks side to side a bit.
I've had a main dealer and an independent (non-Merc) say there's nowt wrong with it, but then when you ask them what they felt, it never sounds like they even got in it! These plus one other have all looked at the bushings and said OK, but then yoiu never know until you replace bushings.
I'm going to try a local Independent Merc service garage, but it's all getting expensive.
Any ideas?
TIA
Any ideas?
TIA
