W210 Radiator Fan Running ignition off
Discussion in 'Electronics' started by qwiksand, Apr 25, 2011.
  1. qwiksand
    qwiksand New Member
    6
    Nov 1, 2007
    Never Land
    Car:
    E320 CDI W211
    Hello,
    I have a 2001 W210 E220 CDI which has not been used much lately. The radiator fan has spontaneously started spinning ( and consequently drained the battery ) while the car was sitting locked - the only way to stop the fan has been to disconnect the battery OR disconnect the power supply at the fan itself.
    I am looking for suggestions of the source of this problem is it likely to be a failed/failing relay? Can someone point me at the appropriate relay(s) and I can try swapping them out.
    Cheers
    :dk:
  2. rhjcamp
    rhjcamp Active Member
    60
    Apr 13, 2008
    Essex
    Car:
    R-Class, & R171
    Hi, did you ever find out the answer? I have the same problem! Mine, I think is related to the fact that I accidentally spilt about 8 litres of water all other the boot and the rear relay fuse board! Ta
  3. mersum1es
    mersum1es Hardcore MB Enthusiast
    1,252
    Aug 9, 2012
    Finland
    Car:
    W219, W220
    Running fan is due to lack of voltage either fan acu or engine ecu. Check all fuses first, and all wire connections.
  4. horgantrevor
    horgantrevor Hardcore MB Enthusiast
    1,902
    Jan 14, 2011
    Car:
    w202 c43 & w210 E220 CDI estate w219 W221
    I had a fault on same car it was due to implausible signal at brake light switch
    And i found a dirty connection for fan
  5. rhjcamp
    60
    Apr 13, 2008
    Essex
    Car:
    R-Class, & R171
    Seems to be fixed with a large amount of electrical cleaner spray, mopping out boot and re-charging the battery! Hint to self, check before putting a garden roller in you boot for leaks!
Share This Page
